The goal is to have advanced timing when the engine has a light charge entering the cylinder. You could also look at as a non-vacuum retard, with full charge enerting the cylinder it will burn faster and you want less timing. The lighter charge burns slower, thats why if you locked your distributor advance you would have pinging at full throttle but not at part throttle.
