Thread: kick panel area
Old 06-19-2005, 09:43 AM
2KWIK4U's Avatar
2KWIK4U 2KWIK4U is offline
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
Paul,
I ran out and took a few pics of my kick panels and posted them in my gallery. Sounds like yours may not be installed if you can see the cowl bar where it bolts to the floor/frame. Its a fiberglass panel that fits between the door hinge and cowl bar and extends to the rear between the door sill and floor. The assembly manual was extremelly vague in the area of installation and I really couldn't understand exactly how it was to be attached. I modified them but cutting them apart and reglassing them together to get a better/cleaner fit. I welded the bolts that go thru the cowl bar and attach the hinge from behind since they are inaccessable after the panel is in place. Carpet is glued to the panel and I also carpeted the area forward of the panel which is basically the inside of the body. Hope this helps.
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
