CB,
Eh' get the Holley HP.
I ran the exact same 3310 carb and 282S cam; Same compression as you too on my last car. Good by not great. You will like the new HP carb with a little more CFM better on your FE the way its set up. I run the Holley 830cfm HP now. Works great with some moderate jetting and Power valve changes. Email me if you need help on what I ended up with. Get some break-in time as others have suggested and see what you think. Make sure you don't have one of those dinky stellings air cleaners on there. Odds are the HP carb and a good filter setup is your next purchase.
Duane
