Tap off the driver's side of the bottom fuse of the passenger's side fuse group. ("fuse 4") It's on when the ignition switch is on or in the accessory position.
If you want power only with the ignition switch on (but not on in the accessory direction), use the double wire that goes to the ballast resistor - #43 (white) on most cars.
