Old 06-24-2005, 06:18 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Steve,
I am obviously not close enough to come help you, but maybe if you could post a little more information about the problem, some of us could help you via the posts. For instance you said the motor was running. Did you make any changes or anything? You say it won't start now. Does it even sound like it is trying to? It could be something as simple as a loose connection, bad unit if you are using an MSD or other type ignition box, or even crossed plug wires or timing if you have did anything with these. Sorry I can't give you more, but I am sure there are people closer to you that will be able to get you going soon.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
