Old 06-26-2005, 09:26 PM
Chris D Chris D is offline
Cobra Make, Engine: RMC. 306 Windsor, TFS Track Heat heads, X303 cam, TFS Upper & lower manifold. Accufab t/b, 24 lb inj's, Autronic ECU. Tremec 5 speed,
Question Jag diff noise(es)
At the risk of starting something , let me ask the question publicly that seems to get aired often in Cobra conversations? How much gear noise and backlash should we get from a Jag' diff as used in many Cobra kits? Furthermore, will the impact of using a Power Lok diff make any great difference over an open diff.
Before the responses come rolling in, my question does have a bit of technology behind it as I recently had a power lok diff re-geared with new 3.54:1 gears (Dana 44's) and replaced all that could be repalced without being silly.
It still has some backlash and I reckon it's from the internal splines; magnified by the rigid mounting of the diff housing. Gear and bearing noise is minimal. Word of warning. make sure the nuts used on the output flanges - where the disks fit - are NOT nylocks. Use metal locks as the nylon melts under hard braking. This bit of advice is from the Jag' manual.
Finally, the Power Lok centres on these diffs have cast steel spider gear carriers which do break. These carriers, arranged as a cross, are the cams sitting in V blocks that lock and unlock the clutch packs. The interlocking cast steel carriers (2 piece) are becoming difficult to get now and any that are out there are very worn. I had a toolmaker make me a set from tool steel and anyone is welcome to have a look if interested.
I also have detailed service and instructions on these locking diffs. They are actually American from Thornton - first used in Jeeps in the 50's, I think.
Now tell me about the noise levels please.
Chris
