Old 06-28-2005, 05:13 AM
Tony Cram's Avatar
Tony Cram Tony Cram is offline
Cobra Make, Engine: 1991 RMC 1966 427SC replica, 302 Cleveland, Edelbrock manifold with 600 Holley double pumper.
Thumbs up GTHO Phase III Specs
Stiffy,
Found this in a couple of ford forums. GTHO phase III specs with 351C 4V 780 cfm carby
Type: Conventional, watercooled, four-stroke, reciprocating piston type
Capacity: 5.763 litres (351 ci)
Number of cylinders: 8
Configuration: Front mounted, longitudinal, 90 degree vee
Head design: Pushrod and rocker actuated overhead valve with hydraulic lifters
Fuel system: Holley 780 cfm four barrel downdraught carburettor.
Bore and stroke: 4.00 x 3.50 inches (101.6 mm x 89.0 mm)
Power output (DIN): 370 - 390 bhp (276 -291 kW) at 5400 rpm
Torque (DIN): 380 lb/ft (513 Nm) at 3400 rpm
Compression ratio: 11.5:1 (varies by 0.5)
Impressive from the factory in the early seventies.
TC
