Old 06-29-2005, 02:35 AM
69 Mach I's Avatar
69 Mach I 69 Mach I is offline
Cobra Make, Engine: No cobra YET. Making do for now with a 69 Mach I
Default Replacing rocker arms. Other than the arms, do I need anything else?
I currently have some Crane rocker arms, part number 36800. These are 1.6 ratio arms for a 3/8 screw in stud. I want to put some full roller rockers in there. I am thinking about the Comp. Cams pro magnum rocker arms, part number 1331, also 1.6 ratio for 3/8 screw in stud. I know I need taller valve covers to accomodate the rocker arms and am prepared to order the 3.75 inch Ford Racing chromed aluminum valve covers, part number 6582-R302 as well. Do I need anything else? Also, would you use a stud girdle on screw-in studs or only for the pedestal mounts?
