Old 06-29-2005, 05:52 AM
69 Mach I's Avatar
69 Mach I 69 Mach I is offline
Cobra Make, Engine: No cobra YET. Making do for now with a 69 Mach I
[i]Originally posted by trularin
Taller covers with baffles. Make sure you get covers with baffles. I suggest you get a clear picture of what you are doing with the PCV and/or venting system.
How many RPMs are your turning? A stud girdle is good for high spring rate, long travel, high RPM use and unless you are turning in the 7500 or more range with something like a D221, I would look at putting your money into a few other areas.
the FR covers are baffled. I don't turn past 6300 RPMs and that is only at the end of the 1/4. The springs are stock from the Edelbrock RPM Performers. I do have a pretty decent sized hydraulic cam at
ADV DUR: INT 297, EXH 308
LIFT: INT 538, EXH 534
DURATION AT .50 DEGREES: INT 236, EXH 242 @ 108 centerline
but Edelbrock tells me that the springs can take that much lift with no problem.
BTW, I used to live in Farmington Hills before moving here. Still go back every November for deer season
