Old 06-29-2005, 10:05 PM
millennium200 millennium200 is offline
Cobra Make, Engine: SPF with 514 and tko
Default valve spring tool
Desertson,
The best valve spring tool I have found is made by Moroso. Their tool will fit most any size stud and will lock in the compressed position so you can get the keepers in and out with no problems. Summit Racing has a copy for only 49.95 part #sum-906784. Also I do not try to keep the piston at TDC because most any air compressor will force the piston to the bottom of the bore anyway.
