Terry....you can remove it from the firewall side. Unbolt the flange, remove the steering wheel, turn signal switch, and steering wheel flange and pull the 3/4" shaft out from the firewall side.
If I remember correctly, the 3/4" shaft will go down through the aluminum column from either direction.
