Old 06-30-2005, 07:08 PM
ItBites's Avatar
ItBites ItBites is offline
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
Blykins,
If you want to run a cast crank, the key is to have a perfectly straight, true, set of journals in the block (read align bore and hone). If you do this, you will get the most out of a cast setup.
I'm no Ford guy, but I can tell you that if it were a BBC, I'd feel better if revs were limited to 6000 on a long-stroke, cast crank. 550 hp, no problem.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
