Old 07-02-2005, 09:48 PM
byron w byron w is offline
Cobra Make, Engine: shellvalley 428 ford
MIKE, I ALWAYS STARTED IN THE CENTER, THEN THE NEXT FRONT, THEN THE NEXT REAR AND SO ON. I HOPE I MADE MYSELF CLEAR
ENOUGH. ALSO, I DO NOT KNOE IF YOU HAVE ARP OR STOCK FORD BOLTS. IF ARP CALL AND ASK THEM. IF FORD, HOW OLD ARE THE BOLTS? YOU CAN CHANGE THEM BUT I WOULD HATE TO. I WOULD GO WITH THE STOCK FORD SPEC IN THE MIDDLE OF MIN AND MAX. IF YOU DONT HAVE A SHOP MANUAL POST AND I WILL FIND OUT FOR YOU.
GOOD LUCK, YOU WILL BE FINE
BYRON
