Old 07-03-2005, 12:42 PM
Bernia You have too much lift for those springs. I talked to comp cams tech 2 weeks ago, the max lift is .600" Coil bind is at 630" with the valve spring hieght sent at 1.90"s I am going with a 587,607 lift cam and have been told this is tight. the spring need .060" not to break or override the coils. Call comp cams and talk to tech line, they will tell you the same. Rick Lake
