Old 07-04-2005, 10:13 AM
blykins blykins is offline
Default 406FE & Desktop Dyno Cam Results
406ci
4.130" Bore
3.78" Stroke
Iron FE heads with 2.09" intake valves and 1.66" exhaust valves.
10.5:1 CR
750cfm Carb
Edelbrock Performer RPM dual plane intake
I've tried probably 15-20 cams this morning. I've tried Crane, Comp, Crower, and Isky.....solid flat tappets, hydraulic flat tappets, hydraulic rollers, and solid rollers. Actually I've tried everyone that I could find on the webpages. Yes I'm bored. I didn't change the other engine specs....just changed cams so I could find the cam for my wants/needs.
The most horsepower that I can get out of DD2k is 513hp with a mechanical roller cam. Actually I got a couple of 500+ hp cams from my research.
What's really floating my boat though is that I tried several solid flat tappet cams from each manufacturer. There were two that gave me approximately 490 hp. Crane has one that gave me 491hp ...but it's a very wide LSA....so it would probably idle like a Cadillac.
The next cam is a one from Isky. Now get this...
108 LSA, 240 degree duration, but only a .530" lift. Desktop Dyno is showing 491hp at 6500 revs...478 lb-ft at 4500 revs.
Does this make sense for such a low lift?
I'm trying to pick out a cam....and right now I'm doing all the bench racing and researching I can because none of the tech lines are open today. :-)
I really don't think I wanna go with a roller cam. The performance margin that I've found isn't worth the headache and extra $500.
One other thing I've noticed is that when I switch to a single plane intake, the hp goes up considerably. By using that same Isky cam and a single plane intake, the horsepower goes up from 491 to 545hp at the same rpm range. Does this make sense? Is it really that much of a gain? If so, it's definitely worth the price.
Comments are encouraged....I'd like to get all the info I can.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
