Old 07-04-2005, 03:53 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Default Scat 393 Stroker kit.
I have a stoker kit from my last motor available. It was destined for John Walsh and I was saving it for him. It's gathering dust now....
It's a Scat nodular stroker crank with a set of Eagle "Sir" "I" beam rods and .030 TRW forged flat top pistons that have been custom flycut for twisted wedge heads. I had a valve head break at about 2,000 rpm (luckily) and it has damaged one piston although it could be reused...it just got beat up a little on the top. The rings are total sealed gapless and the whole package has about 2,500 miles on it. The setup had a zero deck height with a 1969 351 block. The crank and rods are perfect as are the bearings. ( I also have a 1969 351 block already clearanced for a stroker if anyone wants it cheap and doesn't mind paying the shipping on it or picking it up.)
$500 plus shipping to you.
Email fxbill@comcast.net
