It's a good approach, Brent.
I would start by asking some FE experts what you can expect for a reasonable power range on those Iron FE heads. What heads are they?
If you know you are using those heads, I would base everything off of that, unless you are willing to swap heads w/ something else.
If the heads are only good to 5500, then maximize your idle-5500 range with the right intake and cam.
If the heads are good 2000-6000, then go for that.
And so on.
Your heads I would say are the "limiting" factor right now, in that you know you'll be using them. If you didn't have heads, you could tailor it more and do what you want.
Just my 2 cents.
J.P.
Ohio Cobra Club
Token Gashole
