Old 07-05-2005, 07:16 AM
BUCKEYE COBRA's Avatar
BUCKEYE COBRA BUCKEYE COBRA is offline
Cobra Make, Engine: Backdraft #20 302 T5
Default BDR Broken U Joint?
Looking any any tips to replace a rear u joint (at the brake hub).
Experienced a loud banging under driver side rear while driving home from a parade yesterday. I first thought I had dropped a drive shaft. I pulled over and could not find anything hanging from the bottom (not that you can see much without a lift..).
I was able to nurse it home (2 - 3 miles). After pulling the rear driver side wheel, I noticed that I could slide the axle back and forth 2 inches. When I rotate the axle it bumps once per revolution right where the u joint is.
Haven't had time to look at it close yet. It there any secret to removing the rear assy?u joint boot?
I need to get fixed quick as the Good Guys car show will be here this weekend.
Thanks,
John
