Old 07-05-2005, 08:17 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
The most likely problem is with the ignition box. If it is the stock Ford ignition the problem you describe is common. The only way to fix it is to replace the box. The other thing is to check the wiring. Check all the connections to the box.
Don
