Just got off the phone with Barry If we did a big order 3+ Barry/ Karen said they would knock off $ 100 off the list price. The reason the radiator is a lot higher is that Griffin does the mounting of the brackets on the radiator. So it should just slide right in like the old one. Barry said the reason that they do that is because if they mess up on on of the welds of the brackets then it comes out of their pocket not B & B's pocket. That makes some sense to me because welding aluminum is very different than welding steel. Don't know if this is what you were hoping for but this is the answer. The brass radiator is a 4 core radiator; so will the aluminum dissipate the heat quicker even though it is not a 4 core? Griffin makes their radiator differently to achieve the results so which do you do? If we order from B & B then mention to Karen that you are part of this order at the reduced price.
J.A.
