Old 07-07-2005, 02:46 PM
Yetiman's Avatar
Yetiman Yetiman is offline
Cobra Make, Engine: Arntz/SBC/Jag
You should optimally be around 83 degrees C while driving. It will naturally go up a bit after your stopped for a while, so when your driving you seem fine.
It is a little warm when stopped, so it's probably time for a more affective fan setup.
I think it is worth checking the fan flow directions, as it sounds like you should indeed have a pretty effective cooling setup.
As for running water vs antifreeze, running straight distilled water will run cooler than anti freeze.
Water is a more effective coolant than antifreeze. Antifreeze simply has a lower freezing point (and adds anti-corrosives).
I have been running Distilled water, Water Wetter and 15% antifreeze and my coolant temps never go over 84 degrees C while driving even in the hottest weather, and even when stopped in traffic for extended time, it never exceeds 88 degrees C.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
