Old 07-07-2005, 04:18 PM
DAVID GAGNARD's Avatar
Aaron;
You need to talk to the guy/shop that rebuilt the motor and balanced it and see what it was balalnced at,more than likely 28 or 50 oz,but you never know,it may have been 0............whatever weight it was balanced at will determine you flywheel........when my rotating assy. was balanced at Keith Craft's shop,they provided me with three or four "spec" sheets giving all weights,balance numbers,date they did the work and tech that actually did the work signed the papers,they also had the part numbers I think for the crank/rod/pistons/rings/bearings,very helpful if and when I need to freshen up the race motor..........
BTW; mine was balanced at 0.........had to have my 28 oz. flywheel re-balanced to 0 balance which KC did also.........
David
DAVID GAGNARD
