Rob,
You would think that by doing the math you mentioned it would be enough. Same thinking here. But I constantly see most of the fuel injections built with 58mm throttle bodies on them for a BB Ford.
Heck what is the single throttle body on the 4.6L Fords 70mm or 72mm. Now compare that to the 400mm you just calculated. Something does not jive.
Than again maybe 50mm is more than large enough for a BB and 58mm is over kill. Maybe someone in the know will chime in.
Chris
If you can read this, thank a teacher. If it is in English, thank a soldier. If it is in ebonics thank your senator.
Learn Ebonics here.
