Old 07-09-2005, 05:07 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Default Pole Position Adjustable Upper A Arms
I have a new pair of Pole Position adjustable upper A arms for Mustang 2 suspension. I mounted these arms and then removed them to run another Pole Position A arm. They have been mounted, but never used....in "as new" condition except for the cotter keys and 1 rubber boot that was pinched when I removed them.
Specs are as follows:
Mustang II Adjustable Upper Control Arm For Stock, coil-over or Air Ride Suspensions Replace Your Stock Upper Arm With The 9420 And Adjust Camber and Caster Precisely! Install These Uppers While Utilizing Your Stock Lower Arms or Easily Replace Both Upper and Lower Arms For Total Adjustability.
List price $199 ea.
$325 for the pair... a $75 savings! My loss, your gain..
email fxbill@comcast.net
