Old 07-10-2005, 08:40 PM
thejoker21 Rick Long built a HR with 2 accell throttle bodys 10-12 years ago. 2 77135 kits where put togeather. The car ran very good after it was setup. You will need to add a larger fuel system supply lines, 1/2" to supply and 3/8" return. A port system may be better and easier to do. You may want to look into a TWM system. I don't think some of the guys would be too happy if you are cutting up a virgin TP manifold. You may want to look on e-bay for a spare manifold single 4 barrel, you could mount a 1350 or 1550 cfm throttle body on a 4150 flanged manifold. This will give you all the cfm you will need for your motor. The brain or PCM is up to you. I use a Speed pro system, the new name is FAST. Rick Lake
