Old 07-11-2005, 06:41 AM
69 Mach I's Avatar
69 Mach I 69 Mach I is offline
Cobra Make, Engine: No cobra YET. Making do for now with a 69 Mach I
Originally posted by trularin
Open valve cover.
select a rocker that appears to be all the way down.
Unlock the set-screw.
Unscrew the rocker nut ( note the tension on the nut )
turn rocker arm sideways.
pull push rod.
Reverse to install.
make sure you set either lash or hydraulic stop, depending on the lifter used.
Hope this helps
Cool. Thanks a bunch.
