Old 07-11-2005, 08:44 AM
69 Mach I's Avatar
69 Mach I 69 Mach I is offline
Cobra Make, Engine: No cobra YET. Making do for now with a 69 Mach I
Originally posted by vettestr
Hey 69,
This should be checked on every engine built !! as you never know if somebody machined the hell out of something before it came home with you. Adding a big cam and different rockers ratios also changes this contact point. Your builder knows this and checked during assembly so do not worry about your engine IT WAS checked during build if a good builder and it will put up with some error anyway. Vettestr
All of that aside, would it even be possible to fit an 8.6 inch push rod in a 351W that normall takes a 8.150 inch push rod?
