Old 07-11-2005, 01:43 PM
nevermind65 nevermind65 is offline
You don't necessarily need p/s. The Cobra set-up had a separate pump used exclusively for the hydroboost. If you were looking at hooking up a vacuum pump, this should be about the same and you'll never have to worry about vacuum again.
Why not just change the cam if it's too big? Sounds like it is causing more headaches than what's it's worth.
