Originally posted by nevermind65
You don't necessarily need p/s. The Cobra set-up had a separate pump used exclusively for the hydroboost. If you were looking at hooking up a vacuum pump, this should be about the same and you'll never have to worry about vacuum again.
Why not just change the cam if it's too big? Sounds like it is causing more headaches than what's it's worth.
Hehe may be when we rebuilt my engine again, we will run with a hydraulic cam. But now, no.
Ok, if my project won't work i will buy an electric vacuum pump. But first of all i want to try my project. What is your ideas about my project?
