Old 07-12-2005, 08:41 AM
TonyMadrid's Avatar
TonyMadrid TonyMadrid is offline
Cobra Make, Engine: A&C 351W, C4
Default Hose
Hi Jer,
I got mine from a NAPA store. It was a straight length about two and a half feet long. If you're using the gas tank that came with the A&C kit, you'll have to try to make the hose run as straight as possible, with no kinks. Also, make sure that the hose you get is fuel compatible.
If you can't get it from a NAPA store, check your yellow pages for a shop that specializes in gas tank work. They may be able to help you.
Tony
