Old 07-12-2005, 10:10 PM
RON N BKFLD's Avatar
RON N BKFLD RON N BKFLD is offline
Cobra Make, Engine: KMP241 427 S/C 482 Shelby
rnunn,,,,,,jag rear end. the upper bracket has a front and rear , if you are 180 off the u-joint flange will hit frame opening.leave all
bolts loose until all are started, including the 2 big bolts in upper bracket. You will have to alum panals removed for access.
One of my upper bolts tried to cross-thread, I had to chase threads in welded nut, finally got it.
RON N BKFLD
