Old 07-13-2005, 07:51 AM
blykins blykins is offline
Default Enlarging FE Main Bearing Oil Holes
Guys...
Reading Steve Christ's book, he has a standard on if the main bearing oil holes need to be enlarged or not...and gives the spec on how much should be showing.
He doesn't, however, tell how far to drill through....
Are you supposed to drill the hole out for the length of the oil hole itself....? Or are you just supposed to enlarge and chamfer the opening?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
