The
oil pump is driven by the bottom of the distributor shaft through a long rod that drops into the
oil pump gear. You'll need to fabricate a "drive shaft" long enough to reach all the way from the pump up through the distributor hole and finally to a drill motor to spin the shaft.
To save time and wear and tear fill up your
oil filter first.
