Old 07-14-2005, 01:59 AM
69 Mach I's Avatar
69 Mach I 69 Mach I is offline
Cobra Make, Engine: No cobra YET. Making do for now with a 69 Mach I
Stud mounted rockers screw into the head whereas pedestal mounts are pressed in. The stud mount rockers allow for a stiffer valve springs that you would want if you have an application where your spring open pressures exceed 280# (e.g., a bigger cam or a roller cam). This would cause a pressed-in stud to work lose, which is a bad thing. You want a stud that screws in. You can get 3/8 or 7/16 inch studs. Get the 7/16 studs as they are stronger. The price of the roller rockers will be the same.
I can only please one person a day but today is not your day. And tomorrow isn't looking too good either.
