  #27 (permalink)
Old 07-14-2005, 08:35 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
If you want to run tight clearances regardless of block material, cover you hinny by running oil that's on the light side, coated bearings and an Accusump to avoid dry-start problems. Lighter oil reduces pumping losses.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
