Originally posted by blykins
Not too uncommon....could be just the difference in jets on that side paired up with different runners on the intake.
I'm not to sure I follow you. The primary jets in both carbs are the same size (#68), the secondary jets in both carbs are also ther same size (#80) and both carbs have the same size power valve and secondary spring.
