Any good parts house should carry Dorman plugs. As far as removing the cam plug I do it from the front of the block using long socket extensions with a good size socket on the end throught the cam bores. A few good whacks and the plug should pop out. Just be careful of the cam bearings. You can wrap a rag around the extensions to prevent bearing damage if your not replacing them. I've never had much luck trying to remove the cam plug from the outside of the block. May be someone has a good trick to do so. I'd be interested to see myself. G.
