I used studs on the bottom end for strength. I used bolts on the top end because on some installations there is not enough room in the engine bay to pull the heads if you use studs. This forces you to pull or lift the motor to remove a head.
David J. Seed
Q: What makes a good racer?
A: Size 14 shoe, size 2 hat.
Buddy Baker, NASCAR Hero
