Old 02-26-2000, 11:29 AM
Zderf
Guest
Posts: n/a
Hey Rob.... now I find out!!!! Just spent $285 on the thing W/O your discount. Poop.
On the remote oil filter block acting as the check valve, thats great nuze!!! Hank, I assume you came off of the filter block using the port marked with the arrow pointing away from the filter? Also, how did you mount it? I'm looking at 3/4" round frame cross member which does not lend itself well to the stock clamps which are meant to mount ot a flat surface. I see that the clamps properly located on the cylinder are critical.
Any advice?
Thanks... Zderf
[This message has been edited by Zderf (edited 02-26-2000).]
