The MSD distributor for the FE has a larger diameter shaft (same as a 429/460 ford), and you use a steel gear for a 429/460 distributor. When you press the new gear on the shaft, you have to make sure the gear distance specification is correfct, and maintains that distance after pinning it to the shaft.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
