Old 07-23-2005, 06:29 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
X,
One thing that is not talked about much, but I have noticed myself, is that the gear on my comp cams roller cam had sharp leading edges on the teeth, so it was recommended by somebody on this forum, and I did, to use a dremel to buff the edges smooth to the touch. I have not yet ran this motor to see how durable it is. I plan on running a steel distributor gear with it as well. I think I remember in that person's post, that they said they do this on all engines they build with roller cams, and have not seen any wear problems. I think it also depends upon the engine design itself, as some engines may get less oil to the teeth when running, and have a predisposition to gear wear/failure, such as the sbf.
Just curious, did you ever check for this on any of your cams/engines? Maybe this could have been a contributing factor?
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
