427 sidepipe installation on a Kirkham
I need some past experience help. I got the header tubes bolted on with no problem. The driver side tubes matches up in body opening perfectly and allows the sidepipe to have enough clearance on all 4 sides. My question is on the passenger side the tubes turn out parallel to the ground and the header tubes are longer than the driver side which does not allow them to cleanly fit in the body opening. How do you get the sidepipe in the opening and slip over the header tubes. I though about lifting the motor up about 2-3 inches to get enough clearance to fit the sidepipe in? My exhaust is from Cobra Restorers.
Thanks,
Robbie
