Something doesn't sound right here...have you figured it out yet that the header tubes are numbered opposite? Using the stamped #'s on the flanges, #1-4 go on driver's side and #5-8 go on passenger's side.
The reason I ask is that the driver's side has the longer header tubes that go all the way down near the opening. The passenger side goes out parallel, but this is not a problem because the bend is in the sidepipe side to compensate. Should not have to move engine at all...
Joe
