  #28 (permalink)
Old 07-30-2005, 10:43 AM
freeagent 427's Avatar
freeagent 427 freeagent 427 is offline
Cobra Make, Engine: 1966 427 cobra 427 fiberglass shell with intents of a Square tube Aluminum frame.
Origianlly posted by Grumpy:
freeagent 427,
Looking at the little Lincolns thas AM, both set at 16.5 and running perfect.
Maybe the lower pressure is the 25 opening on the tip using 23 wire, possibly dunno. Works for years and with the shop fans going full tilt boogie in the 100 degree Texas heat.
We use this combination to eliminate and "dips" or "sprays" the will ruin the average tip and liner on any brand MIG welder.
Try a combination that best suits your welding criteria and feel, this was just a suggestion and not fixed, TOO MANY VARIABLES.
grumpy
I didn't say you were wrong in your gas setting I just like to run 20 or higher. It sounds like you have built a few of these cars compared to myself only working on one car with many years welding experience.
