I just went through this so maybe I can help. The reason your axle is longer is because of the ABS ring. In order to pull my wheels closer, I used a set of 5 lug axles from a six cylinder non-abs Mustang axle. I also had to use the calipers, brackets and rotors from the six cylinder because I switched from a Mark VII axle setup that was going bad. All of the housings measured the same from a Mustang GT, 6 cylinder and Mark VII. Since you already have the calipers and rotors, you should be close. Let me know if I can be of any other assistance.
