08-02-2005, 05:57 PM
KY
The initial time is 32 degrees? That's extremely too high.....needs to be 12-16 degrees.
You need to make sure the distributor is installed correctly....and the timing is set correctly.
Pull the dizzy, pull the #1 spark plug, stick your finger in the hole and turn the engine over until it blows your finger out....
The timing pointer should be pointing at 0 on your balancer.
Put the dizzy back in....point the rotor at the #1 plug wire as you're installing it....
Make sure the firing order is correct...
13726548 for a 351W firing order....
