True,
How hard is it for you to pull your transmission? The way mine is I can have it out and on the bench in 20 minutes by myself. A little faster if I have someone to help hold it as I don't have a transmission jack.
Once you get the worst off of your car the Wet Paint will really make it look good. And the more times you go over it the better it gets. Also a very slick finish and bugs just wipe off easily with a dampcloth if you don't let them set and bake on for a day or so. An example of the slickness is this. On the 69 Cobra, which is a fastback I used to lay my polishing cloths on the trunk lid while I was working on it. After one time over it with the wet pain I laid them there as usual and they slid right off. Now I have to lay them on top or on the work bench.
