More info needed.
Manual or Automatic?
Which Flywheel?
Which Bellhousing?
Assuming you have a manual transmission 460 with a standard 176 tooth flywheel and a bellhousing that maintains stock starter geometry, you can get a nice gear-reduction mini-starter off of a production 1995 Ford F350 460 Manual Trans Truck. They are about $120 + core at any parts store, and usually come with a lifetime warranty.
That said, you should also be made aware that there is no starter-to-flywheel gear lash adjustment on a 385 series engine starter mount. So, you should check the lash. If it's wrong, you could damage the flywheel or starter or both. When I installed the starter in my combo, the lash was very wrong. I have a Lakewood bell with a 176 tooth flywheel. I had to modify my starter so I could obtain the proper gear lash and I believe that's due to the Lakewood bell. Hopefully you won't have to.
Byron
