I have installed a 5 point in my B&B and it went real well. I used Simpson's. I wanted the Y harness but they discontinued it. I bolted the submarine belt to the steel plate under the seat with the belt bracket sticking out enough to allow adjustment. The shoulder harnesses bolt through the first frame member behind the fiberglass behind the seats. The only problem is getting the angle right as it comes through the fiberglass and over the seats.
I chose not to use a V-harness because I wanted to finish the holes into the passenger compartment with bezels.
I can get pictures easily.
Rob
