Jams, I do not have pictures. I know the newer frames have better mount locations to facilitate a better angle of the lap belt eye bolts (there is a welded pad inboard of the transmission tunnel tubes). Just go through the bulkhead and to an eyebolt mounted to the thick tube that makes the shelf behind the seats. BTW, you will probably need a right angle bit if you are doing it with the body on. I used bezels from finishline.
